YesFor those on a tcu tune, are you still on the stock trans cooler?
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Yes. But needs a bigger cooler for the track.
That’s what I thought. I don’t track and my temps rarely ever go past 170Yes. But needs a bigger cooler for the track.
I live in the California Sierra Nevada foothills at an elevation of about 3600 feet.Another fun question. Has anyone ran their car at sea level and also ran it at some decent altitude? (Above 3k feet elevation,) I know the standard conversion rate for turbo cars- but specifically curios about our car. I am always in the weeds with something.
It depends on how hard you drive, regardless of fuel.Hey everyone I have a little bit of a controversial topic or one that just has mixed opinions. So I was hoping to get some more opinions. Okay let’s say you are running E60-E70 in your car.. Is it a good idea to still use the 2step colder plugs- (HKS-M45iL etc?) Or because ethanol burns colder it is not needed?
No dragy for each by chance? I live at 4,500ft elevation so I am just very curious what time (ish) I would be at sea level. Conversation tables are too general.I live in the California Sierra Nevada foothills at an elevation of about 3600 feet.
I have also raced at Sacramento Raceway (RIP) which is near sea level. I obviously don’t have anything like a time slip from when I am at altitude, but it definitely seems to have less power than at lower altitude.
There is a part controlled by the ECU for turbo durability according to elevation.Another fun question. Has anyone ran their car at sea level and also ran it at some decent altitude? (Above 3k feet elevation,) I know the standard conversion rate for turbo cars- but specifically curios about our car. I am always in the weeds with something.
your pulling upwards of 6 degrees on one of the pulls. but other than pulling timing this is actually one of the best lozic logs ive ever seen, boost looks good, ign timing looks good, fuel pressure is great, trims are great.Hi,
Please rate my log. Lozic ecu 1.5 bar, tcu Lozic, intake Injen, Wagner intercooler, met injection. What do you think, I cannot improve the acceleration time of 100-200 km (about 10.5 seconds)
Regards,
Bogdan
This looks like it is right after the ECU was reset is that correct? Maybe after it has made it all the way through the “adaptation” phase. Post another log. But yes I agree with sneakerB overall good log.Hi,
Regards,
Bogdan
Yes, the measurement was made after replacing the ECU. Thank you, gentlemen for yours valuable comment regarding the acceleration technique. So far I have done it at a speed of about 90 km and full throttle.This looks like it is right after the ECU was reset is that correct? Maybe after it has made it all the way through the “adaptation” phase. Post another log. But yes I agree with sneakerB overall good log.
IMO- this will be mainly be for sound. Unfortunately on our cars this provides very little HP improvements. Still a little bit but not worth it if you are only do it for performance. But if you love the sound then go for it! Our cars tune and fueling is most important/impactful. Post a log once it has fully reset.Dokładnie, testy był
What do you think about exhaust upgrade- cat back and secondary downpipes?
Regards,
Bogdan
Replacing the ECU doesn't mean a full reset?IMO- this will be mainly be for sound. Unfortunately on our cars this provides very little HP improvements. Still a little bit but not worth it if you are only do it for performance. But if you love the sound then go for it! Our cars tune and fueling is most important/impactful. Post a log once it has fully reset.
Exhaust and secondarys. Are pretty much pointless other than noiseDokładnie, testy był
Regards,
Bogdan
So after you put the new ECU in it will go through the “adaptions value” phase. Basically a learning phase for the ECU. The ECU is learning what fuel you have and all other outside factors. It does this before fully advancing the timing and allowing the car the most power etc. Hopefully that made sense!Replacing the ECU doesn't mean a full reset?
I am sending another log on another ECU from Lozic. Which one to choose?Exhaust and secondarys. Are pretty much pointless other than noise
