Ok with me, once it is set right I'd never move it again.If they did that, the headlight assembly would still be broken and unadjustable...
Sounds like the headlight adjusting mechanism is broken and simply needs to be replaced.
Doubt you could order parts for the headlight assy. and the whole thing is probably expensive
It's has to come up about 5" at 4' away from a wall. That's a lot of shimming!
Checking the other side will explain a lot.
