LordKOTL
It could be twisted down. If I remember it looked like it could go straight down. I wanted the valve sitting flush just in case I did something dumb in the future and something tall enough to hit the underbody panel and was strong enough to rip the fumoto valve off.It looks like your valve drains to the side. Can it be installed to drain downward? I plan to install an access port and drop the oil directly onto a large drain pan/container, instead of using a flexible extension hose.
I didn't need the extension for mine. I believe somewhere on these forums (maybe this thread) I have a photo of it mounted.
(kit is here, white plastic bend is what I'm referring to)
I got a plastic attachment for the nipple that straight 90deg bends down . My last oil change I didn't use the plastic hose, just the 90deg plastic bend. It drained straight into the drain pan.
I like the idea of the hose, though, because If you have a couple of 5qt oil jugs you can drain right into them. You just have to man the actuator so you don't overfill them.
