Stripped drain plug
^^Wait, but the jack stand isn't touching the control arm. Looks to be 1-2" below it? So if your floor jack fails, car would drop a small distance before jackstand catches.
Wouldn't placing under the knuckle be better... Or better yet under the factory pinch weld location?
Also, no chocked rear wheels??
Btw, pretty good aim to get it to drain right into the jug :).
correct - gap between jack stand and control arm. Jack stands are only used if my jack(s) fail. ~2" gap = good enough for me.
Jack stand would hit the rim/tire - and not fully align to the area you circled
yes rear wheel are chocked - I mentioned that in post #14 from years ago
Can't put a jackstand on the pinch weld - as I am jacking from the pinch weld
Not good aim - have a ~6" clear hose between quick change valve and oil container.
Given the typical low torque spec for a drain bolt, I can't imagine how anyone could round one off. Even if the problem were overtightening, I'd expect the threads or drain pan to die first.
It could also be some jackwagon who tries to use an imperial socket on a metric hex head... Like if you take it in for an oil change and you get a bad tech.
Doesn't the pinch weld run the entire length? I squeeze my pinch weld adapters in like 12 inches down from the exposed part for my jack, then put the jack stands in the open spot (with puck adapters).
I gotta say - I wish there was a better way to jack up the car - my Subaru had a couple of points in the center that were called out in the manual that you could use, like the transmission cradle or whatever. I'm a little too scared to jack up using the rear diff.
I HAVE thought about the Harbor Freight arm adapter.
I expect the thread is stripped in the sump not the bolt. If its alloy its a lot softer than a bolt. A mechanic would not do that. Finger tight with a nip is all that is required if you haven't a torque wrench and mechanics don't need a torque wrench. I would say it was done by an idiot with absolutely no idea using VFT as the primary option.
Cutting out the bottom cover..............it's there to provide streamlining under the car....
Rather than replace with a standard drain plug. Slap a quick change valve on there for tool-less oil drains going forward. Keeps my driveway more clean with no spills or splashes.
  • EZ (AL-106) Silver 14mm-1.5 Thread Size Oil Drain Valve Adapter
  • EZ (EZ-106) Silver 14mm-1.5 Thread Size Oil Drain Valve
  • EZ Oil Drain Valve (L-001) L-Shaped Hose End - 3/8" L-Shape
This is brilliant! I hate having a big wide catch bucket full of dirty oil and trying to pour that back into an old jug. My warranty is up in ~ half year and I'll start doing my own oil changes. If D.J. or anyone is still using this: I'm curious if that little valve holds up to the elements over the years.
I've had my Fumoto valve in for right at 2 years, and it hasn't leaked. Of course, that's only about 4 oil changes for me, but it's still very convenient.
And last summer I modified underbody cover with a twist port, not as fancy as @D.J.'s but similar to the one under the filter (I think mine's technically for a 5 Series), so this winter's oil change I didn't pull either panel.
Thanks! Good to know about the underbody removable plastic cover. I'm surprised the Stinger doesn't have one stock in the plastic underbody cover. My wife's ~2015 Kia Soul had a removable piece ( ~ 4"x6") from the plastic underbody cover for oil changes.
