ghodge
I'm trying to troubleshoot a shaking/trembling that takes place when I apply throttle. It only happens under throttle and generally gets worse the more throttle I give it. As soon as I let off the throttle, the shaking goes away regardless of what speed I'm coasting at that point. The car has recently had an alignment but that hasn't resolved the issue. I plan on getting my wheels balanced to see if that helps but wouldn't I have shaking whether or not I was on the throttle?
I need to preface everything with the following in case it helps in the line of troubleshooting. Last year I was driving the car with my JB4 installed using map 2 for 93 gas and map 3 for an E30 blend. I ran into a situation on the freeway where I gave the car a lot of throttle and the car started shaking and the power was breaking up. There was no check engine light and it felt like the car was in limp mode that would not clear until I turned off the ignition. I was able to repeat this again and once again there was no check engine light. I pulled the the Densos that were gapped to .024 and all of the plugs had the electrodes worn down to the nubs in about a year and a half of driving. I replaced the plugs with the HKS M45IL gapped to .022 and that seemed to resolve the issue. Late 2022 I removed the JB4 because I get free oil changes with my dealership and took the car in. Fast forward to about two months ago, I start getting vibration, with no check engine lights. I reinstalled the JB4 and it pulled no codes. I have since replaced all the coil packs and pulled all the plugs for examination. Everything is still gapped to .022. I still get the vibration so I'm looking elsewhere.
Is there anything in the driveline that needs to be looked at? Could wheels out of balance cause vibration only under acceleration? I'm trying to figure this out before handing it over to the dealership.
Thanks,
George
Thanks,
George
