ht_addict
For those who have lowers there car, swapped out the sway bar I recommend new Endlinks. I went with the SuperPro. You can really feel the difference. Road noise is also greatly reduced over rough surfaces.
Road noise is reduced by these end links?For those who have lowers there car, swapped out the sway bar I recommend new Endlinks. I went with the SuperPro. You can really feel the difference. Road noise is also greatly reduced over rough surfaces.
I disagree my White Line End Links are good at resonating noise they need some kind of damper to help with this, when I replace these it will be with a different brand name . they do make a difference in drivability over stock links with no flexUnless your old links were broken, you are not gonna feel any difference, and definitely wont hear any difference in noise.
Are you sure your stock end-links flex?I disagree my White Line End Links are good at resonating noise they need some kind of damper to help with this, when I replace these it will be with a different brand name . they do make a difference in drivability over stock links with no flex
Maybe you need these dampers as your end links, for your stinger.I disagree my White Line End Links are good at resonating noise they need some kind of damper to help with this, when I replace these it will be with a different brand name . they do make a difference in drivability over stock links with no flex
You can feel the difference? In what? (lighter wallet?)
I'm with ya there.Only thing making my wallet lighter is the a-hole politician in Ottawa, who thinks he can save the world by taxing the fk out of us.
