Hey everyone, Did some reading and pretty sure these rears wont fit but wanted to get some thoughts before i give up on them
Found a set of used Niche MISANO 20” for sale.
Front: 9 wide +35
Rear: 11 wide +35
Thanks for any help!
The fronts will fit fine but the rears will poke out too far. I have 20x10.5 +42 in the rear and they fit great. Maybe they poke out a quarter inch or so.
Meant to post these here when they just got here but then forgot, a few things in the way of me throwing these on but... soon :)
TE37 Saga S-Plus in Bronze Almite finish
Specs will be:
Fronts: 18 x 9.5 +22 (Face-4), 255/40/18
Fronts: 18 x 9.5 +38 (Face-3), 255/40/18
Going to stick with the squared setup until I order a new pair of 18 x 10 +35's (Face-4) for the rear to retain OEM stagger spec and match the concave, hope to post with the wheels mounted once the car has coilovers installed, soon!
Did you get them mounted yet?
Thoughts on this fitment? I think the rear offset is too high but maybe with spacers?
Front - Forgestar 19x10 +45 Nitto NT555 G2 285/35/19
Rear - Forgestar 19x11 +56 Nitto NT555 G2 305/35/19
Not a chance. Your wheels won't even turn, if you can even get them on.
I'm considering selling my Genesis Coupe and getting a Stinger. I was hoping to keep my wheels and put them on the Stinger since the hub bore and PCD is the same, but looking at this thread I'm guessing the offset I have is too extreme
This is what I have:
Front: 19x9.5 +25 235/35/19
Rear: 19x9.5 +15 255/35/19
Could anyone confirm this isn't gonna work out like I hoped it would?
Not only are more open wheels with fewer and more slender spokes easier to clean, they also tend to allow cooling air for flow through much easier.
Those wheels you have on the Genny Coupe are more often found on high-end luxury cars, because they tend to form a wall when spinning at hwy speeds, so they tend to be much quieter. You see similar "closed" wheel designs on G80's and G90's. OTOH, open spokes can act like fan blades and whip up a lot of air flow - and noise.
There is no right or wrong, just different compromises. What is best depends on how you run your car and what is more important to you.
If performance is what you are after, the first thing to do before deciding on whether you want to keep those wheels and put them on the Stinger... is to weigh them.
Reading up on some information here. My question is would a 19x9.5 +22 aodhan DS02 fit? I’m currently on stock height but will be lowering the car eventually.
I’m just trying to get wheels first before dropping the car
in front? rub, rubba, rub. that's too little offset for that wide. especially lowered where is your clearance turning?
Not just yet, waiting for R&D on a rear spring adapter by Riaction to be able to run swift springs in the rear, wanting to start with stiffer spring rates right away with a revalving too.
The only options for the width are +15 and +35. I’m trying to go for a square set up
Unless I just stick to 19x8.5 all around.
from my reading 8.5 c. +34 square is the most likely to work out with a variety of tire widths. if it were me going square, I would go 8.5 wide mid-30s offset and 245 tire. if I felt wild I'd try 255 square but ultimately that would depend on the actual wheel. and no, I can't advise on a brand or model of wheel. that's what the pro shop guys are for. happy hunting.
Found these forged wheels with tires on FB marketplace.. So tempted. What do you guys think?
Wheels:
5x114.3
19x9.5 +30
19x10.5 +35
Center bore - 66.1
Tires:
Continental DWS06
245/35/19
275/30/19
Anyone running a similar wheel + tire size setup? Also, what hub centric ring would I need in order for these to fit on the Stinger?
Your spot on with your assessment there
Wheels:
5x114.3
19x9.5 +30
19x10.5 +35
Center bore - 66.1
Tires:
Continental DWS06
245/35/19
275/30/19
Centerbore on a stinger is 67.1
Thank you so much. This gives me a sense of what I should be shopping around for. Really much appreciated. With these specs,
(19x8.5 +mid 30s) could I use them being lowered and stock height?
