Door power question
nagisa
Going to be wiring in an ambient LED system all throughout the car
Each door comes with it's own controller that connects to each other wirelessly but needs 12v power to each controller
Anyone aware of if there's a 12v constant power in each door? Guessing to control the windows should have that
From a video I found it looks like there's a harness.
Anyone got a diagram know which wires to tap into?
In case anyone else needs this info
From testing the harness all pins are no power except for the battery (pin 10)
Ill attach the wiring portion below
All other portions are no power when the cars off
I needed this for car interior ambient lighting for each door
The best option and what I settled on was the Illumination pin (6) which gives 12v at night or when your headlights are on
So during the day the lights are off unless you put on headlights or parking lights
And if on auto, automatically turns on at night
This is just for the rear, but front should be the same, will finish this project next week for the front doors
update: passenger door is good
driver side seems odd tho, it does have illumination but no specifications on the diagram of which one is illumination
and there's 2 grounds
will have to bust out the volt meter again for this one
Pictures of how its going so far?
not familiar with one from australia but probably similar?
its called symphony ambient lighting kit from aliexpress/china (it's like $100 for the kit)
What port did u get the power from so it turns on at night? Im trying to connect my last last which is driver side door.
I need to find a constant hot for front passenger door from orange hardness plug diagram
Looking at the diagrams already provided in this post, it does not look like there is power (hence why the OP used illumination and the ambient only works with lights on).
Finding constant hot (if there is one) is the easiest thing in the world to do, just unplug the harness, then with multimeter or probe, connect to ground and then (with car fully off) test the pins.
Yup found a constant hot on the harness all done with the ambient lighting.
Also hows your jb4 do you get alot of codes or limp mode when flooring it hard looking into them
So far i got aem intake xforce exhaust system with mid/downpipes
No codes or any issues at all with my JB4. Granted, I keep it mostly on Map 1 since I I am not running WMI or mixing gas
Isnt map 2 for 93 only and 91
Correct, map 2 is for 93 octane.
Unfortunately there is no 93 octane where I live. There is one gas station that caries I believe 101 octane racing gas, and absolutely everywhere else tops out at 91 octane.
Oh ok thank you
