Borla Install
footsurg
Just got the Borla exhaust for my Stinger and wondering if I need to buy a new gasket to go in between the catalytic converter and the X pipe when I install? Thank you!
Technically yes, but you might be able to get away without it. Really just depends. I used gasket maker alongside the gasket and I'm fine after 20k miles.
Thank you for the input. I’m going to get one from O’Reilly auto parts. Going to put the exhaust on this Saturday. Pretty excited!
If the one you pull out is in good shape, you can probably reuse it, but if you can get new ones readily, then go for it.
I recommend replacing the gasket when installing a new exhaust system to ensure proper sealing and avoid potential issues.
