The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
It actually looks normal to me but I still need your 60ft 0-60 and trap speed to compare with mine. Post a screenshot of the log and let’s see how crazy the boost tapers at high rpm. I’m able to do 11.7-11.8 with extra boost at 5500 and 6000rpm. Pearly is the one who inspired me to do map6 stacking and it works as expected.Those running lozic ecu/tcu with bms wmi what wmi settings do you use? Installed wmi and only ran a 12.00 1/4mile. Seems very slow for AWD from my understanding. Thinking part of the reason may be the wmi settings? This was just autoshifting, but I think it still should have been a little faster?
You should post the screenshot of your run and let that timing blow off everyone’s mind. I wouldn’t expect lozic tune would adapt CPI that crazily well.Forgot to update everyone.. I finally got my CPI installed. I sent off for new ECU and TCU revisions to compliment it.
That log is from the run, but I guess it was grouped with others. I guess it's possible I let off before the 1/4 as it's not markedHonestly I don’t think this is an accurate draggy run. (Probably because of the satellites.) Your trap seeps would definitely be higher than that. So either you let off before the 1/4 or it’s a dragy error IMO. Do you have other runs or a log that is from this run?
That log is from the run, but I guess it was grouped with others. I guess it's possible I let off before the 1/4 as it's not markedI'll have more logs/runs tomorrow
Ya this log only has a few pulls in it. But Yes if you can get a 1.8 60ft or better my guess is 11.6-7 for you.That log is from the run, but I guess it was grouped with others. I guess it's possible I let off before the 1/4 as it's not markedI'll have more logs/runs tomorrow
Stock LC is crap with AWD, not nearly enough boost at 2200. Anything less than 2500 RPM is an anemic launch, so you really need a TCU tune with LC torque limits disabled.Launch at 1800-2200 (play a bit)
Shift 1-2 really early... like 4500 hit the paddle and then each subsequent gear shift at 5000 to 5500.
80/20 and map 0 with trigger 1@randyare you using 100% meth? also I'm assuming your using jb4 for the meth control? What map are you running?
I run only a jb4, WMI, and Lozic TCU and my ET is 11.80.
If you have a TCU and AWD, should be launching at 2500+ RPM.Yeah, of course but he has a Lozic TCU.
The fastest G70 in the world launches at 1800. Unless you're faster then a 10.7@128mph, you may want to give it a shot.If you have a TCU and AWD, should be launching at 2500+ RPM.
What I do is once staged at the line (full tree) is hold the brake with my left foot, at the first yellow I mash the gas and at the third yellow, let off the brake.
It just bogs because there is no boost at 1800.The fastest G70 in the world launches at 1800. Unless your better then 10.7@128mph, you may want to give it a shot.
