Custom drive mode keeps resetting to default
killinghall
Perth, Western Australia
Anyone seeing the car reset your custom drive mode settings every now and then? Mine does and I can't figure out what's causing it.
I don't use driver profiles if that has anything to do with it.
what are the default settings, comfort everything?
Are you saying this behavior is new?
Did your year of car hold the setting between power cycles?
Are you saying this behavior is new? Did your year of car hold the setting between power cycles?
I'm not referring to power selection via the knob/dial, if that's what you meant?
It's the individual settings within custom mode. I have specified:
Engine/Transmission: Sport
Steering: Sport
Suspension: Comfort
Every now and then these settings revert to Comfort.
I know this post was a while ago but I experience the same issue on the last of the MY23 Stinger GT.
It happened again today on the way to a dealer service.
Every so often I flick to Custom and find my settings of PowerTrain Sport, Suspension Comfort and Steering Comfort have all defaulted back to Comfort.
I don't know what causes it as I am not changing the settings in the menu
I do move back and forwards between Eco and Custom on the drive mode knob. Unless it is an inadvertent change to SMART and it causes it maybe..... I have no idea.
Obviously a software event there somewhere.........
