clemson85
2019 GTS with 8800 miles. I get 20 mpg city in Sport mode and around 30 mpg on my trips to the SC coast in Smart mode.
As I mentioned, the major difference between my long freeway road trip and my rural highway road trip was that on the freeway one, I set her for ~75mph, and then just tried to keep her at that speed. If I saw a car ahead of me going slower I would keep the same speed and change lanes around them without slowing down or speeding up--as much as possible. The route I took (I-5 between Portland and Seattle) was not that flat. However, because I was just cruising at one set speed boost was very low to no boost at all, and I think that's what helped me get the mileage I got--the fact that I wasn't slowing down, and then subsequently speeding up.I have no idea how some of you are getting 30+ mpg highway with the V6. Someone even reported 35mpg. Are we driving the same car???
I couldn't get 35mpg unless I was coasting downhill lmao. Slight exagerration, but still. Not sure how you guys are getting that kind of mileage on flat land.
Is your weather always cold? And what mpg do you normally get?If you are concerned about fuel economy before purchasing, it will hamper your experience of the Stinger. You will frequently be thinking about how much gas you are burning when you floor it. It makes the car less fun.
With that said, fuel economy (including it uses premium fuel) is the only reason I sometimes consider selling. Unfortunately fuel economy is frequently on my mind since 90% of my driving is city driving in a cold climate.
If you mainly do highway driving, the Stinger is decent but is still on the lower side of fuel economy.
I've also made spreadsheets that compare fuel consumption to kilometers driven and yeah the Stinger is expensive. This is expected for what the Stinger is.
The trip that I took with a 31 MPG tank was all in SMART mode with the cruise set to 79.As I mentioned, the major difference between my long freeway road trip and my rural highway road trip was that on the freeway one, I set her for ~75mph, and then just tried to keep her at that speed. If I saw a car ahead of me going slower I would keep the same speed and change lanes around them without slowing down or speeding up--as much as possible. The route I took (I-5 between Portland and Seattle) was not that flat. However, because I was just cruising at one set speed boost was very low to no boost at all, and I think that's what helped me get the mileage I got--the fact that I wasn't slowing down, and then subsequently speeding up.
Nice! I was in Eco for my 30mpg, and I believe the net elevation gain was about 400' with elevation changes throughout.The trip that I took with a 31 MPG tank was all in SMART mode with the cruise set to 79.
We don't all live in the same locale and drive the same way. Somebody driving in mile-high Denver will see different mpg results than another driver near sea level in Houston. Also, there is a difference between indicated mpg (on dashboard) vs. actual mpg (calculated at fill-up with actual miles driven). What I consider "city driving" might be very different than another person in another city. Take some of these reports with a grain of salt.I have no idea how some of you are getting 30+ mpg highway with the V6. Someone even reported 35mpg. Are we driving the same car???
and mostly downhill. How is your mpg average on the return trip?Driving down to ABQ (83 MPH average, or so) from here I got around 29, that was in Smart/Eco, cruise control and all the driver assistance on.
There is about a 500' difference in elevation between here and there, can be hilly in some parts, which goes both ways.and mostly downhill. How is your mpg average on the return trip?
At 25mpg, you are well ahead of the median. Obviously driving style plays the biggest role.35k on 19 GT2 AWD see ~25mpg in mixed driving. I live near Santa Fe so have many 'hills'. And yes a leaded foot will kill the mileage, but as others have said, sometimes you just gotta pass some grandparent. Well worth the cost![]()
That's how you achieve the lowest fuel consumption on all vehicles, not just the Stinger.+1.
Get a bluetooth OBD2 dongle or anything else that let's you monitor boost pressure. I've driven my entire commute route and not see boost pressure blip off 0.0 psi. So the car basically acts like a normally aspirated engine. Takes a good bit of planning to drive like that in traffic, because you'd be essentially hypermiling. You might piss off cars behind you, because your acceleration will be rather mild. Same thing while slowing down and letting the car coast and use as much of the momentum as possible, instead of the brakes.
You can get good mpg. Question is whether you have the discipline to do it, and whether it is worth it to you in order to have an engine that lets you rip when you do want to.
I have about 11.5k miles on my car and my lifetime mpg average is around 20.3mpg.
GT2 11.4 MPG lifetime
