Drone Fix Question re: Resonator
gdiddy
I have a 21' GT1 AWD that I've had a muffler delete on. Tried all the different methods to reduce exhaust drone at ~2-3K RPM including sound deadening the whole trunk + wrapping exhaust. Also have custom welded-on exhaust tips. Still have drone. I have a newborn daughter and would rather not make her go deaf as I drive around :)
Possibly a dumb question, would aftermarket resonators replacing the stock resonators do anything? I don't have an aftermarket exhaust per se, so for example, would the MRPB resonators swapped out for the stock exhaust do anything? If not, what can I tell my exhaust shop to do in order to reduce drone? Any tips?
There's something about stock stinger catback. As soon as you touch it it starts droning. Put stock mufflers back if you want to get rid of it. Replacing stock resonators with aftermarket will most likely increase the drone.
Sure. Don't want to replace mufflers :( any custom resonator cans out there for stingers?
rhe aftermarket tips clear the bumper, correct? I have no drone with the MBRP and some tips. The muffler delete is probably what’s killing you.
Vibrant ultra quiet resonators should fit in the stock muffler location, have your exhaust shop weld some in.
And if you need it, I have two new OEM muffler sections you can have, just pay shipping.
