Led Bulbs
BIGBREW
I put led bulbs in my 18 (can't stand the yellow hue of halogen). Is it me, or are the headlights pointed in an X. They look like they need some serious adjustment.
yours might be pointed too low or out of adjustment. this has been talked about quite a lot. I had to raise my headlights, a lot of us do because from the factory they are not high enough. but your question might be about something else.
Cross eyed headlamps?
I think they need more than clocking. I'll try adjusting them one night this week.
They are down and crossed instead of up and straight.
what LED bulbs did you get? there are very few LED bulb replacements that work well in projector style headlamps. Headlight revolution has some good info about it, that's where I've purchased bulb upgrades for our other vehicles.
If it is just that they need adjustment there is an up/down adjustment screw and on headlights that do not have the dynamic headlights, there is a hole that says L-R for left right adjustment
the mechanical adjustments are on all ;)
Check the bulb itself then, might not be installed in the housing correctly?
Haven't had a chance to drive at night yet. Looked much better in the driveway though.
FAHREN 9005/HB3 LED Headlight Bulbs, 60W 14000 Lumens Super Bright LED Headlights Conversion Kit 6500K Cool White IP68 Waterproof, Pack of 2 https://a.co/d/6yLCwhg
