Oh, had to go back to some of your other posts, I see that you have a G80, not a Stinger. Shame if they didn't put launch control in those.
Do you have an H or E shifter? Some have said if you have E shifter, some you can hold up the parking brake button up to build boost. I know mine isn't strong enough to hold under launch boost though.
Another option is the stop lamp wire snip.
Can you disable both stability and traction control (hold down the traction control button for 3+ seconds), if either of these are active, then any wheel spin at launch will likely feather the engine, if you can get both disabled, might prevent that.
