Tire Fitment: 245/35/20 & 285/30/20
I want to possibly do the same, but I think I got lost in all the different setups, LOL! I guess what I am looking for is the best setup, on OEM 19" wheels, if I am looking to go a bit wider AND not be an issue for a tire shop. I think I am hearing 245/40 front, 275/35 rear is that setup. Is that correct?
You can definitely go 245/275 on the oem wheels without issue.
So spoke to someone from Discount Tire and they recommend not going wider than 235/40 fr and 265/35 rear. They thought the 245/275 is really pushing it (my words not theirs) and the gap in the front would be wider than stock. Thoughts?
You can honestly find a ton of people reporting 245/275 on their stock wheels... but I'll help you out with a video link.
It will fit fine. The rear tire will stick out just a tad but think of it as added protection for the OEM wheel :p
Rather than asking them for their recommendation (they have to be conservative), you should just confirm if they are willing to install the 245 and 275 tire.
I’m running Front 245/35/19 et: 32 & Rear 275/30/19 et: 38 at stock height without issue, I also know of another running the same but in 20” without issue.
Based on your specs above you should be OK.
Was wondering if that increases the ride height
Thanks! They did say that they can install, but sounded like they were unwilling for liability reasons.
Probably about 12.5mm (1/2”), make a comparison using the attached calculator.
