Also, I'm pulling the trigger on Zerex Asian-Specific 50/50 P-HOAT antifreeze instead of the AMSoil due to what DJ mentioned regarding the phosphate content.
^^Has your temp gauge inside the car indicated any over heat conditions?
Given how low your levels are, I'd do as earlier in the thread, post #5. To ensure you have no air elsewhere in the system. Personally this is not my tool of choice, but better than nothing and better than having an air pocket circulate throughout.
My tool of choice is a vacuum filler (uview 55000 or similar).
DJ - I squeezed the upper radiator hose roughly 70-80% and the coolant was about to overflow.
JSolo - Temp gauge hasn't prompted any issues, and researching across the forums, someone with worse, but identical, issues did not get an overheat code either.
When I squeezed the upper radiator hose, it sounded and looked like air bubbles escaping. After a few consecutive squeezes, no air released.
Should I top off the reservoir or is it harmful to mix new with existing coolant? (Survey says Valvoline-Zerex is compatible with OEM specifications??)
Just grabbed one of those along with some Valvoline Zerex from Amazon.
Any concerns with just draining the fluid and replacing it like in this video?
I feel like he missed some key steps to do this correctly??
Also my buddy said new model cars actually are worse off when you flush the traditional way (i.e. distilled water through the system a few times)
You have to decide for yourself what is too "frequent"
If the coolant level is low, add enough specified coolant to provide protection against freezing and corrosion. Bring the level to F, but do not overfill. If frequent additions are required, see an authorized Kia dealer for a cooling system inspection.
