Lozic ECU + TCU + AWD Tune
that's what I'm thinking too. I mean if you hammer it at 20 MPH then you are passing 60 with a bunch of momentum. that's got to account for a second or more in some cases.
100%, Probably more than a second, considering the boost is already built and the rpms are already climbing in 3rd gear as well.
okay I’ll give it a try tonight.
I may change my pressure 3 and -8.
Suggestions?
I thought that is what you were at already? I’m currently pressure 1 and -13%
I am, but I'm wanting a change :D
Reading comprehension is not my strong point! If you have a log pay attention to boost drop. That’s how I decided on my -13%. I don’t like hard shifts so why I just did pressure 1. 3 would scare me.
Haha My mistake as well.
When does -13 shift at which rpm? And I get you. Pressure 3 are hard shifts but got use to em.
It’s shifting around 5,600. (Even sooner in 1st gear.) When I get my revision I’ll be doing pressure 2 and -10%. Only because I’ll use map6 to hold boost longer through the curve.
How much were revisions for tcu? Doom mentioned 300 or so
Nope. Only the cost of shipping is all I have been charged ($50-$75) can’t remember for sure.
So the TCU can be reprogrammed? I was always under the impression that once it was programmed it locked
