Wobbly
GenesisG70
1000 Posts Club!
Orlando, Florida
I noticed my rear view mirror is not sturdy and is wobbly any one knows how to fix it?
Is there a bolt or something that I can tighten?
Thank you.
There should be a set screw on the post. Just dropped mine off to get retinted so i cant double check. I'll update later if nobody else verifies
Thank you sir!
Did you get it fixed?
Get it? Screwed..
Same issue! Checking to see if this worked out for you!
Yes you have to remove 2 plastic covers the rectangle small one then the large c shaped one the you will be able to see the screw at the bottom of the shaft that holds the mirror you just have to tighten the bolt and now is sturdy and awesome.
