I think you can only get the JB4 box bundled with or without the Bluetooth module. Upgrading the factory
spark plugs is a must for any tune, they prevent misfires since you'll be pulling higher boost.
HKS plugs are most expensive than
Denso plugs but the
HKS's are higher quality. You also want to gap the plugs correctly. (Between .024 and .028). The BMS PNP
fuel wires for the JB4 are optional like the
EWG wires. The
fuel wires are for modifying fuel/air ratios.
You probably want a good oil catch can to capture some of the crankcase oil blowby (car maintenance mod). I'll recommend
ram air snorkels. I have the
JA airscoops but those are no longer being made. The
Velossa Tech snorkels function the same though. The
snorkels will replace the factory air inlet elbow and allow a lot more air into the stock enclosed airbox or open-air intake if you have those. Don't worry, the
snorkels don't suck to water during rainstorms (this is my daily driver so I know).
