Daniel @ K8 Stinger Store
1000 Posts Club!
- Oct 24, 2017
Is excited to present to the Stinger forums:
ATQ Subframe Chassis Collar Kit
(BUY NOW)
Description:
These small aluminum rings make a night & day difference in the way your Kia Stinger feels when doing day to day driving.
Used to correct the chassis's basic geometry by filling the gap between the subframe bolts, subframe, and the cars chassis bolt holes.
These will help to protect & prolong the vehicle's undercarriage parts lifespan, while also alleviating rear end wheel skip & shimmy over rough terrain.
The vehicle's engine, transmission, suspension, and the uni-body are mounted on the subframe and when installed, these work by correcting the geometry setup.
By eliminating the gap, vibration through the chassis is greatly reduced improving driver feedback & handling, as well as helping to prevent frequent alignments.
Kit Contents:
(10) Aluminum subframe chassis collars
(4) Custom machined OEM grade-10 subframe bolts
Installation Instructions:
Installation Guide: (FOUND HERE)
Installation Video: (FOUND HERE)
Vehicle Applications:
2019-2022 Genesis G70 (All Models)
THANK YOU FOR LOOKING!
