gelberdaniel19
- Apr 4, 2022
2018 GT2 AWD, 22k miles, stock except for slotted rotors and better pads
I'm hoping to get some feedback on noises I've been having for a few months now. This noise is kinda a grinding noise in the front, maybe in the left wheel well or maybe behind/under the steering wheel. It happens when I turn at low speeds, and its worse when I turn right. It also happens when I switch from reverse to forward, when I start moving forward. With these two combined, it's the loudest (for example, backing into a parking spot and pulling out to the right). I say grinding sound but I'm not sure that's 100% correct. It sounds to me like it gears rubbing past each other and setting into place, if that makes any sense. It's always 1-3 creaks/grinds and then it tapers off with a sliding or setting-into-place sound. I can also feel it in the steering wheel. Turning my wheel makes me feel like I'm trying to make a part slide past another.
When I lift the front of my car and rotate my left wheel, whenever I change directions, I can hear what I think is backlash. It's a single clear clunk that happens as I'm changing from forward to backwards or vice versa. This makes me suspect that this might be two different sources, as this sound is definitely not the grinding noise described above but could be the "setting into place" sound.
As the car warms up, the noise gets quieter and eventually stops. After about 10 minutes of driving, I can steer hard left and right in a parking lot and it only makes 0-2 creaks and the sound of "setting into place" doesn't happen. The sound is clearest when turning out of a parking spot that I backed into many hours ago, so I'll record audio tomorrow when I leave work if there's no clear ideas here. I took it into a dealership 2 weeks ago but it was a 45 minute drive. I didn't realize that the sound got better as the car heated up and it was gone when I dropped it off. They inspected the suspension and brakes and found nothing wrong, but who knows how thorough the inspection was.
Lastly, I haven't been able to hear the sound with the windows down, though I never attempted to for the "first and bad" noise of my drive because I'm forgetful. I'm not sure if it's the ambient noise or if it's a problem with the steering column, but opening the windows seems to make it harder to hear.
Some ideas I've looked into are:
- Brake pads. It's not this.
- CV Axle
- Tie rods
- Differential (maybe backlash? I don't know what backlash sounds like though)
- Steering column. Not sure if the reverse and forward thing could be caused by that though.
- CV Axle
- Tie rods
