D.J.
2500 Posts Club!
- Feb 24, 2018
- Location
- Toronto, Ontario, Canada
Last night - hit a pothole on my way home - unavoidable I suppose. It was camouflaged by a shallow puddle of recently melted snow
Drive home - Minor vibrations as if I lost a wheel weight. - no loss of pressure. for the remaining ~30 minutes drive. Park car and forget all about it.
Next day - today - drive to work - about 0.8 kms into my drive - car beeps and tells me - low pressure in one tire (24 psi)
As I am turning around to go back home - 20psi
then 18psi
then 12psi
then 4psi
Made it back to my driveway
Inspect - arrgghhhh
Pull the wheel off and inspect the inside of the rim - arrgghhhhh
Start with a 5lb sledge and a very beefy drift
Something like this (not my image)
Soon after - escalate to a 10lb sledge
40 to 60 not so delicate, but reasonably accurate, impacts later - I have some something that resembles round again
Inside lip
Outside
Lets try this again - cold pressures
As tire warms up - 8 kms into my drive - pressure holding
After my 70 km drive to work - Pressure = good
Comparisons
I do believe these cheap steel rims are not as strong as alloy - but certainly more easily repairable.
Would an alloy wheel have been damaged over the same pothole - I will never know.
I'll paint them later!
then 18psi
then 12psi
then 4psi
Inspect - arrgghhhh
Inside lip
Outside
Comparisons
