I'm Tony Danza
- Aug 11, 2020
Hey guys,
I'll try to make this as short as possible. The history:
- 2019 GT1 AWD
- Lowered the car on ARK springs about 4 weeks ago, by the book and with factory toque specs all around. Didn't notice any issues, but I didn't drive it much.
- Immediate alignment by a local suspension pro. Still no issues, but again barely drove it.
- Received new Vossen wheels and tires soon after. Went from 18" to 19". Sizes are correct and nothing rubs.
- Started to hear a front end noise, as if it was a bad new tire. Had one replaced under warranty. Didn't fix it.
- I have taken all suspension parts back off, inspected and re-installed, again using factory specs. ARK Springs have both come off and re-installed.
- Everything was tightened down and torqued while the suspension was raised up to normal driving position.
- Top hat alignments are correct, as well as the springs in the perches. Upper blue colored bolt is in the right mounting hole.
- Strut center nuts are both tightened/torqued all the way down and there is no wiggle room between the strut post and top hat.
- Put factory wheels and tires back on. Same noise.
- Cut the bump stop a bit, getting desperate at this point.
- No vibrations or shaking, just the noise
The Noise:
- If I am not driving on glass, it is a roaring, echoing hollow sound that is pretty much constant. Coarse roads are much worse.
- On very slow bumps (gravel or bumpy ice), it is incredibly loud.
- Definitely coming from the right front.
- No grinding or sounds beyond this.
- Recorded video. This is driving only 2mph over some rough ice, passenger side. It does not make this sound if I drive over the same ice on the driver's side of the car:
The car has 15,000 miles on it and I'm guessing I can't take it to the dealer unless I reversed everything back to stock.
Anyone recognize this sound? I am at a complete loss in over 30 years of turning wrenches, as it should be super obvious. Maybe a blown strut, but at these low miles?
I will buy so much beer or whatever for the person that figures this out!
- 2019 GT1 AWD
The Noise:
