Stingerman100
Brand New catless downpipes for rwd should work with awd but can't guarantee anything. 350 shipped in the us only.
These fit AWD as well. You must cut the mounts from the exhaust and either weld them on in the the correct location or have a exhaust shop do it for you. Everything else is the sameZTo clarify they will only fit RWD.
False I already tried and there's a huge gap hence why I'm selling these cause I thought it would. The arks and Jun bl catless secondary's for as I had those way backThese fit AWD as well. You must cut the mounts from the exhaust and either weld them on in the the correct location or have a exhaust shop do it for you. Everything else is the sameZ
I am not sure what you did wrong. I just installed mine yesterday. The pipes are exactly the same. It is only the mounting locations that are different.False I already tried and there's a huge gap hence why I'm selling these cause I thought it would. The arks and Jun bl catless secondary's for as I had those way back
Here are the mounting locations between AWD and RWDFalse I already tried and there's a huge gap hence why I'm selling these cause I thought it would. The arks and Jun bl catless secondary's for as I had those way back
Seems to be a qc issue then because I had it up on the lift and there was a noticeable gap where it connects to the downpipe. It might be due to my catback but I'm selling these so not my problem anymoreI am not sure what you did wrong. I just installed mine yesterday. The pipes are exactly the same. It is only the mounting locations that are different.
The blue is the location for the rear wheel drive mounts on the pipe. The must be cut from the midpipe. Install the midpipe and bolt the cutoff brackets to the mount on the car. Once the pipes are installed and the “cut off mounts” are bolted to the factory mounting points for the AWD crossmemeber, Weld the brackets to the exhaust pipes.
I confirmed with many people before I bought them and then once I installed them, I verified that it is only the mounting bracket location that is different. If you cannot weld them yourself, any exhaust shop or fan shop should be able to weld the brackets back onto the exhaust and it will fit just like they came that way.
Where exactly are you seeing a big gap that you cannot weld the brackets back into the pipe?
Well the issue is I have a welded borla lol the box never came with clamps and I had no other choice unfortunatelyYeah, they fit it’s just the mount. Of course with exhaust you usually mount everything keeping it loose and then work your way from the back to front of the vehicle lining things up and you snug them.
The DC Sports pipes are top
Quality and fit perfect!
I'll keep them safe for you don't worry. No rush just let me know when you're ready thenif you still have these next Friday i think i will get these off you.
Have you tried?They definitely don’t fit awd
