3.3TT Fuel System Cleaner
init3
What are your guys thoughts on using something like this?
I searched our forums and haven't found much on this topic.
I seem to recall reading in the manual that additives and cleaners are not recommended. Why would you even think that your brand new car needs a cleaner? Not for many years.
Actually, Service 2 on the Kia maintenance schedule I got from the dealer has adding Kia fuel system treatment as one of the items. As our climate is considered severe service, service 2 is at only 12 months. :unsure:
Dealer did my 10,000kms Service last week & used “Genuine Fuel Additive (Injector Cleaner)”
It surprised me but if Kia use it who am I to argue.
I'd worry more about the muffler bearings, they're not made like they used to be!
Ah, that's the passage (like scripture, it is). Not "many years", but many thousands of miles. And get Kia's recommended brand(s). I wouldn't be using lower grade gasoline anyway, so I don't expect to encounter any engine performance issues.
As I'll be doing my own maintenance after having the dealer do the first 6 Mth/6,000 KM (Service 1), I'll be putting in the fuel additive at service 2 (12 Mth/12,000 KM) per the prescribed maintenance schedule - to ensure that all the warranty requirements are met.
At least in the prairies up in Canad it's done every 12,000 with the maintenance packages (2,3 & 4) even if you use premium fuel, build up in the fuel system will still occur just slower and in smaller amounts. While it might not be needed right out of the away, as you put miles on the car it will help
The Stinger Tech i spoke with at the dealer said they add to the tank and also add to the vacuum system. Tank method cleans the injectors and vacuum method cleans the intake valves...since GDI.
He basically told me it was a commercial version of the SeaFoam fuel system cleaner stuff.
Adding to the vacuum line seems more important for the intake valves in my opinion.
... vacuum method cleans the intake valves...since GDI.
That's the part I'm interested in - fuel additives do nothing for the valves with a GDI system. Kia (and others) had teething problems with this, when it showed up as an issue after GDI vehicles starting racking up some mile.
Interesting that he referenced Seafoam - I used that on a motorcycle with recalcitrant Mikuni carbs and it worked wonders. Thanks for the info - I'll have to give the vacuum/intakes a shot when that service interval rolls around.
Hopefully a Oil Catch Can will mitigate "most" of the intake valve caking but a cleaner into the vacuum would certainly be beneficial. Better than having to walnut peen the valves later on down the road!
Here's a useful Seafoam video on the application method for a turbo GDI engine.
No.
These cars are brand new. Use top tier gas (google it) ALWAYS.
Can I sell you some blinker fluid? lol...
Do not get upsold.
It wasn’t an up sell....it’s part of the logbook service, the dealer has to seek approval from the customer to carry out any works above & beyond the stated service. As I was not asked this is part of the service the same as oil & filter change, so I’ll pass on the blinker fluid thanks...:thumbup:
So would you need to spray an entire can per turbo?
No, the spray is injected downstream from the turbos and intercooler, just before the (single) throttle body.
They asked me on my first service at 5k per the manual. I declined, still a bit early.
At 58K since I was about to hit 60K milestone I got the fuel injectors serviced/flushed. Seems a proper time at that mileage yes? Any insight on this?
Thanks guys!
Thanks guys!
That's about when I'm thinking of having my done. Likely going to do the walnut blasting though, unless being done at more frequent intervals I doubt chemicals will remove all the buildup with that many miles. There are chemical methods that will work on higher mileage vehicles (I've posted a video in another thread) where the car is ran at 2000 RPM with a slow chemical drip into the intake, but this requires just as much (or more) time and costs as much as just walnut blasting.
