I *think* if the dealer (service writer) recognizes you know a thing or two about the car, they're less likely to try to pass this kind of shit. Probably wouldn't hurt to pop the hood in the future in front of the service writer and take a pic.
Two years ago I had our big (2 stage 28" wide 300cc engine) ariens snow blower serviced due to leaking augur gear seals. This was a warranty repair. Upon receipt, the unit appeared to run fine and no longer leaked. Great.
Reviewing the paperwork,they indicated 2 units of fluid was used. Each unit IIRC was 8 or 12oz. One unit should be sufficient to fill to proper level. Two?!@# Either they overbilled the company or they really did fill the whole assembly to the top. It bothered me enough to check the level. A bit of a pain as several brackets have to come off to reveal access.
Anyway, the spec calls for the level to be 60 to 70mmfrom the top of the housing. Where was the level? Right at the top, filled to the brim. Had unit operation continued, surely the seals would blow out in no time.
I called the shop out on this. They said the guy made a mistake... Right. Either carelessness of plain stupidity. Needless to say, the seals are seeping again. I'll top it off for this next winter, but next spring/summer will replace the seals myself.
Yes when I picked the car up I popped the hood showed the service writer the damage before I left I could not return to the loaner they gave me because it was sold an no loaners were available. The next day the car is at the bodyshop they are paying to repaint both finder bumper and hood and replacing the damaged parts under hood brake fluid got on those paint surfaces and ate through the clear coat. Kia customer service is currently docking the dealership on their point sys their point system where they can lose their franchise if they accumulate enough at these points that's the only repercussions Kia can take against the dealership And I still don't have my car it is still at The Body Shop The Body Shop they said it might take 2 weeks
Holy crap what a horrible experience you went through. Part swappers are the worst kind of "technician". What the hell were they doing that they got brake fluid all over everything and didn't clean it up immediately??
