What is the offset? My TSW 8.5 front wheels clear, with a 40 offset. Brand of wheel, even with the same offset, can vary as per clearance, but not by much I understand. You could always ask the pros (Wheel Werks knows all about that clearance stuff).
Find many great new & used options and get the best deals for 4-Niche M224 Gamma 19x8.5 5x4.5" +35mm Gloss Black Wheels Rims 19" Inch at the best online prices at eBay! Free shipping for many products!
That should clear the suspension easily. I don't think that 5mm more clearance is going to move the tire in relation to the fender. But I would be asking the pros to be sure.
19x8.5 +35 will work fine all around but if you're planning on staying staggered you might want some wider rears.
I'd check out some of our forum vendors (I've used getyourwheels) rather than going though ebay, they can help you find exactly what you're looking for.
Currently, I have the same specs for the front 19X8.5 +35 with same oem tire size. Changing out front tires to 245/40/19 to upgrade soon so you have some wiggle room with tire sizes.
^^^Tyro here: but those both look extreme. I'm guessing the 8.5 with 20 offset will hit the fenders. And I've never read of anyone using a 10" wide wheel in front: would also smack into the fenders if it cleared the suspension at all.
Tire Tech Information - The Wheel Fitment, Tyre Stretch, Rolling Radius and Speedometer Error Calculator. Play with specs, try different settings, compare results
