Dan00Hawk
I took one off today to get some 2022 GT Line wheel info so I could order new wheels.
18x8 with 34mm offset, per the stamping on the back of the wheel.
Weight on my scale with Bridgestone Potenza Re97 AS 02 tire is 55.4 lbs (I verified the scale calibration this morning).
Tire Rack lists that 225/45 R18 tire as 24 lbs.
Therefore the OEM wheel is 31.4 lbs.
So there are some good weight savings to be had with a set of lighter wheels on the GT Line 2.5T.
I ordered a new 19" tire and wheel set (Konig Ampliform 19x8.5 30mm, 20.5 lbs; Nokia One 235/40/19 25 lbs) that'll shave off 10 lbs per corner, but it'll be a few weeks until they arrive.
edit: My new wheels showed up, so I reweighed my OEM set. They came in at 52.0 lbs when I weighed them inside which matches what RM7 got. Maybe the sidewalk I used before was uneven enough to get the 55.4? Anyway...
So that would make the OEM wheels 28 lbs. I don't see the Edit button available on my original post, so I'm not sure how to update that.
