Wheel/tire fitment question
Bulldogging
Looking at some Advan GT wheels, with PS4S or Continental Extreme tires.
Closest offsets they come in to what I've gathered fit well is,
19X8.5 37 offset 235/40/19
19x9.5 38 offset 275/35/19
2022 AWD GT1
These look like they will fit fine with no poke or suspension interference, but I just was hoping for some confirmation/opinions.
Thanks.
19x8.5 +32/19x9.5 +40 with up to 245/40 front and 275/35 rear is a great fit, even with a mild drop. My guess is what you are looking at would work, but I can't be 100% sure. so, I'm basically no help, LOL. Your slightly smaller front tire would likely ensure it fits, and I can't imagine the 2mm difference in the rear would be an issue.
I would go with a little less offset up front like Stingertime said but those should fit fine.
That was the problem I was running into, that is the only option for the fronts.
A wheel vendor told me that 9 inch wide with 35 offset is ideal for the Stinger fronts, and will not poke.
By my calculations it just means an 8.5 with 37 offset will just retract from the fender lip by an addditional 8mm. Should still look good I think.
Thanks for the confirmations.
seeing as you are awd, i would do the 245,40r19 so that you maintain the "stock" ratio of front to rear tire size for keeping the rotations per mile the same for front to back.
