[VENDOR][FS]: Kia Stinger 3.3T - Jun Bl Racing Catback Exhaust System - K8 Stinger Store
Daniel @ K8 Stinger Store
Authorized Vendor
Is excited to present to the Stinger forums:
(BUY NOW)
Description:
The Jun Bl Racing Catback Exhaust System for the Kia Stinger 3.3T is a 100% perfect bolt-on system that requires no modification or welding at all
This replaces the OEM exhaust directly and squeezes all available horsepower from your 3.3T Stinger engine while also increasing torque
Jun Bl's exhaust design produces a deep growling and aggressive sound all the way up through redline
Truly among the best exhaust systems on the market for the Kia Stinger
Vehicle Applications:
2018-2023 Kia Stinger 3.3T (All Trims)
2018-2021 Kia Stinger 2.0T:
(FOUND HERE)
Additional Information:
True quad-outlet dual exhaust which fits with stock exhaust tips
Dyno-proven +30.1 horsepower at 4400 rpm & +5.0 torque at 4400 rpm
Polished stainless steel construction (SUS-304)
Professionally TIG-welded, 3D bending
All hardware necessary for install included
Inlet pipe size: Φ60.5x2 mm
Mid pipes size: Φ60.5x2 mm
CNC-machined flanges
THANK YOU FOR LOOKING!
I'm looking at both the Jun BI Racing Catback and Jun Bl GT Catback. They seem similar but the GT reports higher gains. Are there any significant differences between the Racing and the GT Catbacks?
They are nearly identical, just different muffler canisters, other than that, no significant differences.
Nice! Do you know if the two Catbacks systems will fit on a 2022? I think the 2022 Stinger GTs have larger exhaust tips.
That’s actually a great question.
It is a different part number for the 2022 models, as they are designed a little differently to accommodate the larger tips.
We have not had a chance to update the website to provide the drop-down option to let you select what year you have.
However, we do have them available now, if you’d like to send me an email, I will make sure that you received the right one for your stinger.
Sales@K8StingerStore.com
Thanks, I'll be sure to email you before I order.
I can confirm the fitment is perfect and the local shop that installed the catback said the quality is top tier.
Awesome! Thank you for the confirmation. Glad to hear you are loving your exhaust.
Are you looking to squeeze every bit of power out of your 3.3T?
The Jun Bl Racing Catback Exhaust System is built specifically with performance gains in mind.
This is a true quad outlet dual exhaust that is a direct fit bolt-on part and roars all the way up to redline.
Jun Bl exhausts is amongst the top-tier brands for performance Stinger parts and this Racing Catback System is no exception.
Please note: This product is also available for the 2022-2023 Models!
(CLICK THE IMAGE BELOW TO MAKE A PURCHASE OR TO FIND MORE INFORMATION)
