IME, this is ultra rare to find an AWD car that comes without AS tires. I haven't seen this in years.Yes of course: my AWD GT1 came with the PS4.
I'm a unicorn? Who knew?IME, this is ultra rare to find an AWD car that comes without AS tires. I haven't seen this in years.
Derp.Merp.
Yea I thought so, and no it's not AWD so it shouldn't matter that much. It's super strange though, I don't really feel comfortable at the higher speeds, keeping it straight in the lines is very tough, even with a fresh aligntment.If you are not AWD, there is no issues mixing tires F to R, you do want to have the same size tires as OEM for correct ride height and the same type/use tires, like summer performance, if that's what you are running in the rear. This has been done for years and there are no problems with it. Even using the same tires doesn't guarantee better handling, differences in tire width, rim width, sidewall support, front weight bias, etc., are all too numerous to think that the same tire F and R somehow fixes or equalizes all these things. There are better tires, so you wouldn't want to be putting economy tires up front if running good high end performance tires in the rear. But again, like use and like size, no problem. You are going to wear out rear tires faster anyway, handling is not going to be the same front to rear. It's virtually impossible for it to be.
Freaking classic! I think I watched that six months after picking up my E36 actually!Anyone remember this video from years ago?
My Canadian 2021 AWD came with summers. Michelin Pilot Sport 4 (not S) rated 96Y.IME, this is ultra rare to find an AWD car that comes without AS tires. I haven't seen this in years.
Isn't this something getting sway bars done addresses?
I've done a fair bit of highway driving before and after I got the sway bars done and I find it much more stable at speed
The OEM sway bars allow "hop" or "float" too, and that is noticeable in a straight line when the road surface is up and down. The aftermarket sway bars eliminate "float" almost entirely: my car gives one up and down and it's done. However, on the OEM sways, the ups and downs on Hwy 95 were no problem at high extra legal speed: the rear seemed planted to me at the time: but I've wondered if I would feel comparatively greater stability on that stretch of road with the Eibach sway bars.^^Only if you're going in circles on on/off ramps. Sways bars reduce body roll. There is no body roll when going in a straight line. As been mentioned, the OP's issue is tire or suspension related.
I had felt "hop" in a straight line for over three months: when I got on Oregon 95 and pushed speed well over 140 MPH, the definite feeling of heightened stability was in spite of the humps every few hundred yards: that was with OEM sways, which under those conditions seemed more than adequate: leading to my question above, about if I would notice a difference with the Eibach now, going over the same stretch.^^Help me understand. If the both sides of the car (L/R) are going up and down with the dips/rises in the road, how are the sway bars in play? I can make sense of this if there's a change in one side but not the other - a bump in the road on one side for example. As I understand, a sway bar becomes loaded when there's a change in one side's suspension relative to the other. If a sway bar is too stiff for the application (or adjusted to the stiffest setting), there's a phenomenon called steering where kickback when one side drives over something that unsettles the suspension on that side.
When I last installed swaybars on the last car, the suspension was either fully unloaded (jack stands) or all 4 wheels were on drive on ramps (loaded with weight of car). I can't remember how the car was situated (this was 9 years ago). Either way, all the sway bar endlink and frame bushing bolts all lined up without having to compress anything.
In addition to reducing body roll, the aftermarket sway bars cut way down on the Stinger's "side step" or "twitch" in the rear when cornering.
