Yes it will fit.My '22 stinger didn't come with mudflaps from the dealer. Can I buy 2021 OEM Mud flaps and install them?
There's no need to touch liner when fitting guards.![]()
2018-Current Kia Stinger Front & Rear Mud Guard Kit J5F46 ACA00 & J5F46 AC200 | eBay
Removal of the vehicle from the warranty covered market for which it was produced. Normal wear, tear or deterioration such as discoloration, fading, deformation, blurring, etc. What is not Covered .www.ebay.com
This is what I recently fitted to my '22. That was the best price I could find.
I suggest doing the brake vent mesh at the same time so you don't have to pull the liner out twice.
Do you end up bending the liner doing it that way? It's just a few easily removable clips holding it in place.There's no need to touch liner when fitting guards.
100%. I replaced the OEM ones with rokblokz "regular" (not the "slim"). Significantly more functional, and I think they add some nice visual weight down low. I think the operative term these days is thicc. I also chose to use them to add another layer of side vent mesh, since the rokblokz have cutouts to match the factory wheel well liner.Would recommend the rokblokz mud guards. Much better coverage. Also work really well, big difference between driving in the wet with vs. without. Got to see the results of both.
No. Use existing hardware of one self tapper and plastic plug on front and 2 x self tapper and 1 plug on rear.Do you end up bending the liner doing it that way? It's just a few easily removable clips holding it in place.
