StingertimeNC
1000 Posts Club!
Great numbers!
Should have just installed the Sub Collar Frame Bolts and Eibach Shocks. Made a huge difference in noise and vibration for me.
It is? I think I see a spot or two on the front.Car is dirty as hell
The upside of white!It is? I think I see a spot or two on the front.
Why the concern?Installed the BMS Pedal Tuner. I'm apprehensive about it but we'll see how I like it over the week.
Just concerned that it actually does anything for me.Why the concern?
I don’t know the settings on the bms but on the windbooster, I can’t tolerate driving higher than sport+ as a daily..and that’s with the car on eco mode. The higher settings are race and drag. I think at that point, the car almost drives itself lolJust concerned that it actually does anything for me.
BMS has 9 setting modes + stock and I don’t ever go past 6 for daily driving. Red 7-9 is overkill.I don’t know the settings on the bms but on the windbooster, I can’t tolerate driving higher than sport+ as a daily..and that’s with the car on eco mode. The higher settings are race and drag. I think at that point, the car almost drives itself lol
Finally got my springs installed. I like the way the fronts look, hopefully the rears get settled down more in a couple days. My guy hauled ass in 3 hours..impressive
In that case, I have nothing to complain about lol
I wouldn’t drop more than 20mm due to this, but with mild drops it’s easily manageable, just don’t take grade changes straight on, take them at an angle, even if it means one wheel hangs in the air momentarily. You also do it real slow so the suspension never compressed and further reduces height. Never go in a place you arent sure you can get out of. Park away if you have to.A couple of months back, I cracked my front lip (Maxton V1) while going down, then up two parking lots with varying inclines. I'm at stock height. After that episode, and after getting a replacement lip, I'm just going to stay stock height, or I get coilovers one day to adjust up/down (manually, unfortunately) where I need.
