Devin
1000 Posts Club!
Mine gets hot too, but not at all worth my wireless anchor charger. I'm try the rear ac trick to see if it helps
On my 2020 Stinger, I usually turn one or two AC vents towards the wireless charger to cool it off a bit. Does your wireless charger have ventilating holes on it? The 2021 Stinger got the facelift with the updated wireless charger in Australia.My wireless charger in my 2021 GT stinger heats iphone so much its goes into shutdown mode. Cant use it. Any ideas?
If her iPhone is in a case, that can interfere with wireless charging.It charges my Android with no problem other than insane heat but my gf's iPhone does not seem to get any juice to the battery. Very strange indeed!![]()
I thought that too and there was still no charging even after removing the case. I have noticed that at times the car-charger fails to charge even my phone at random times. Oh well. Will figure it out.If her iPhone is in a case, that can interfere with wireless charging.
I've had my 2022 Stinger for about 3 weeks now and I'm having the same issue. My Galaxy S10 won't charge. It was ok the first 2 weeks, then it started making my phone hot & now it won't charge at all. If you find a solution please let me know.
The vents have nothing to do with it. I've tested the surface temperature of the charger without my phone on the charger and it registered 104 degrees Fahrenheit. Ambient temperature for iphones is between 32 – 95° Fahrenheit.Good to know, thanks. I'll check that out.![]()
get a samsung phoneMy wireless charger in my 2021 GT stinger heats iphone so much its goes into shutdown mode. Cant use it. Any ideas?
