NJ_Stinger
- May 22, 2021
Has anybody installed a cat-back exhaust on a 2022 3.3t that has the factory variable exhaust? Every cat-back I find only only says it fits up to a 2021 (which did not have the factory variable system).
It looks like the factory valve system is part of the actual outlet of the OEM muffler, meaning that you'd either have to cut it off and weld it into the aftermarket catback, or remove the valve system and just tie it up/let it hang there? The valve body/actuator itself is fairly large.
I don't really like the thought of either of those options.
Any information is helpful, thanks!
