andrew tay
error
Yes it usually is. Just checking to see if anyone has actually used it. Some have mentioned it here but no real details about the outcome. I am planning to try it in my build but am not to the point to test it yet.SPDIF should always be a fixed signal, otherwise you run into serious bit truncation
Start with the really easy stuff.... what's your source? Use the best you can get. Also Dynamat in the hatch area improves the bass a fair bitGod I wish I understood all this stuff !
Would like my stock system to sound a bit better but have no idea.
Oh well, might start with removing the mesh stuff under the grilles.
we will figure this out !!Yes it usually is. Just checking to see if anyone has actually used it. Some have mentioned it here but no real details about the outcome. I am planning to try it in my build but am not to the point to test it yet.
Also have you removed the plastic panel on the door to be able to deaden the door skin?
What's my source ? I don't even know what that means..... lol.Start with the really easy stuff.... what's your source? Use the best you can get. Also Dynamat in the hatch area improves the bass a fair bit
Did you have to remove the glass? Any tips or tricks to taking the inner door panel out?I deadened all four of my doors, plus added MLV behind the door card.
It makes a substantial difference in the amount of noise coming in from adjacent cars. There was a bit of midbass improvement, but I was too lazy to take measurements.
I would definitely recommend it for the noise suppression alone.
Source, as in where are you getting your music from. (FM radio, Bluetooth from your phone, Music streaming service via carplay or android auto etc)What's my source ? I don't even know what that means..... lol.
I'm probably just going to start with some Dynamat ( as suggested ) and remove the try adjusting some factory settings and see where that gets me.![]()
yeah ill be doing this as well , but using resonix and some black hole tiles up front in the doorsI deadened all four of my doors, plus added MLV behind the door card.
Yep me too.yeah ill be doing this as well , but using resonix and some black hole tiles up front in the doors
