MerlintheMad
10000 Posts Club!
If the values used are printed on the case, wouldn't we be having a ton of examples of this going on?
The car lovers social network
Automotive components
Automotive Hot or Not
Explore Pet Insurance!
Vehicle hacker protection
Advertise with us!
Timing is everything
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
The Food Order Method
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Reasonable logic and I wish I could agree. If anything, poorly timed engine braking is just making me slower. Ideally, comfort mode would be well suited for the days I’m looking for an “old coasting auto” and then kick it into Sport when I want to push it.This is normal. It's basically downshifting to assist with braking and when you want to accelerate the transmission will be on the right gear so response is better.
I guess it would take some getting used to if your coming from old coasting autos.
In comfort it does downshift when slowing down. However it's a fairly smooth action.Reasonable logic and I wish I could agree. If anything, poorly timed engine braking is just making me slower. Ideally, comfort mode would be well suited for the days I’m looking for an “old coasting auto” and then kick it into Sport when I want to push it.
Monday morning stop and go traffic versus a Friday afternoon sprint on the freeway... but I guess I’m being too picky.
Nope, it's free under warranty. Just ask for it, pretty sure they can charge for it under warranty and be paid. Everyone wins, unless they're idiots which is possible.For those of you who went through the adaptives reset, did the dealer give you any initial pushback that they couldn’t perform this since the car was still under warranty?
How many times did you go through the static relearn? Just once?Slight update. For shits and giggles I tried the in-car adaptive shift reset as described in KGIS. After putting 25-30 miles on the car tonight including frequent stops, the shifts did indeed appear to reset back to how it was when I picked the car up from the dealer. It is no longer slamming into lower gears. I did BOTH the "static relearn" and the "driving relearn" as described in the attached PDF.
Is this all that the service guys do when you take the Stinger in for "harsh shifts" (shift shock)? No computer juju? just hold each shifter position for three seconds (as shown), go through the series at least five times, then take the car out and let it move up through all eight gears and then downshift through all eight gears? (only do the upshift/downshift once?)The KGIS document suggested "at least 5", so I did 6.
Dude I have a 21 GT AWD and just had my car towed to the dealership. Out of nowhere it wasn’t shifting properly, then it would just go into neutral run high RPM then slam into gear really hard. They think it could be a shortage of trans fluid straight from the factory but they have to pull the transmission out to find out more. I only have 3400k mi on my car. Crappy part is they found another issue they think related to the JB4 tuner separate issue from trans so I have to drive there tomorrow and remove it before they will work any further on it. Hopefully tomorrow I will know more about the trans and I can update you. They will Be checking for damage and replacing it if there is. They also said this is unheard ofSo I noticed my 2018 GT1 was downshifting pretty hard, cruised the forums and saw the general consensus was to have the dealer Reset/replace the transmission control module. After a week of them diagnosing it they decided to put in a brand new transmission Anything have anything like this happen? Dealer even said they’ve never had to replace a stingers transmission but thats what they decided was the solve all.
So, there is an actual tool they hook up to the car and then go through these two shifting routines? If going through the routines works, why is a "tool" necessary?Nope, they reset it via the actual KGIS tool, there's an option for it in there. I don't have the documentation in front of me to get the exact name.
Kia service departments are notorious for many "unheard of" problems. Mine suggested that they had never heard of sunroof/roof rattles in the Stinger. Uh-huh.They also said this is unheard of
The tool clears the adaptive shift learning on-demand, no driving necessary.So, there is an actual tool they hook up to the car and then go through these two shifting routines? If going through the routines works, why is a "tool" necessary?
They really do. I had a rattle from I think my hatch they said same thing. Since it’s a newer car maybe all these issues are new to them lolKia service departments are notorious for many "unheard of" problems. Mine suggested that they had never heard of sunroof/roof rattles in the Stinger. Uh-huh.
My dealer said this was the first transmission they ever had to replace on a stinger. They did the “extensive” road test and said it even shifted hard when accelerating.Dude I have a 21 GT AWD and just had my car towed to the dealership. Out of nowhere it wasn’t shifting properly, then it would just go into neutral run high RPM then slam into gear really hard. They think it could be a shortage of trans fluid straight from the factory but they have to pull the transmission out to find out more. I only have 3400k mi on my car. Crappy part is they found another issue they think related to the JB4 tuner separate issue from trans so I have to drive there tomorrow and remove it before they will work any further on it. Hopefully tomorrow I will know more about the trans and I can update you. They will Be checking for damage and replacing it if there is. They also said this is unheard of
Damn man. That’s a whole heap of shit right there. I’m supposed to be getting the same recall fixed too. Hopefully they don’t mess that up too. As much as I search for transmission issues there really isn’t anything out there. Which is good news so I guess we’re just the unlucky ones that got that one car out of thousands that’ something wasn’t rightMy dealer said this was the first transmission they ever had to replace on a stinger. They did the “extensive” road test and said it even shifted hard when accelerating.
So all in all I was cool with getting a new transmission but the messed up my rocker panels and in the process of putting in the fuse kit recall they got some sort Of solder of heat sink on my bumper which melted into it so they even replaced my bumper. On top of the coolant leak
