You can have taller tire and within 3% is considered safe and will not affect car stability electronics but you will go 1-2 mph faster depending on your speed. Also 245/35 and 285/30 are exactly the same size and this is important (at least for AWD).
There are so many people running this tire setup you should not be worried.
will the 32 offset in the front and 40 in the rear affect how they look? Will one be flush and the other stick out more?
They will be pretty close to each other
thank you for responding! but do you know if they are flush with the fender or would stick out slightly?
a +32 and +40 will be very close to flush
Mine are +32 +38
Both front and rear 9" ET33 and 10" ET40 add 19-20mm toward the fenders.
Front will be more aggressive vs the rear since there is more room in the back. Rear should be very flush if lowered, slight poke if not. Front will have very slight poke if lowered and some poke if not lowered. Nothing extreme to me in term of poke but this is subjective.
Mine are +32 +38
thank you!
I am lowered so I think this will be the desired look I am wanting. I’m just trying to measure 2-3 times to cut once. They also don’t have a return policy if they don’t fit or look the way I want.
thank you!
Getyourwheels hooked mine up id contact them and they have measurements
American Racing Crossfires have been on back order for 2 months now and I'm tired of waiting. I found a set of Verde Axis, same design but they're not forged (10lbs heavier), but they only come in a +30 & +38 offset. Would I have to get +30 fronts, +38 rears and add spacers? I'd like a slightly tucked or flushed fit.
What is the size of the Verde wheels front and back, same as American Racing 9 and 10.5?
Also Verde Axis design is quite different vs the crossfire but if you like Axis Verde design you can check 305Forget ft101 or Fast FC04 for flow formed wheels to keep it similar weight as the American Racing. Fast wheels are very affordable but might not be easily available in the USA (it is a Canadian company).
Yeah 20x9...I'm going with a squared setup.
I just noticed that the valve stem on the Verde is on the inside off the wheel. This caused an issue for another member here (can't remember the thread).
305's are also on backorder & can't find Fast in US from a trusted seller. I probably should just be patient and wait for the Crossfires to restock.
looking for a square 19" setup but with what I want specifically I'm stuck with possible these specs and was wondering if anyone would know if these would be safe in regards to clearance to the brakes and strut.
19x9 ET30 (TSW Geneva)
19x8.5 ET30 (TSW Neptune)
Planning on running 255/35/19 Pilot Sport All Season 4.
My other option is a 19x8.5 ET35 (AG M580) but is in limbo depending on pricing quotes on these.
I did check the chart and some other post but I think I'm starting to get more confused than I should for this :cry:
My TSW "Watkins" are a lot closer offset than that: 40 in front, 39 in back; so if you ran 8.5 square you'd have plenty of clearance in front (I am 8.5 in front); a 9" wide in front would push you in another c. 12.8 mm; that would probably rub in front.
(edit to add: if your particular wheel is more deep dish - I'm not looking - then that extra half inch wide for the 9" would be added to the outside and not push closer to the suspension; i.e. the offset would actually be less than 30 in that case; or, the wider wheel could share a bit of dish and positive offset and only move a few millimeters toward the suspension: you'd need to engage the service of wheel people who know this stuff in their sleep :P)
I just updated the sheet with OEM 18" size along with my winter 18" setup. Also corrected the formula for the 18" wheels.
I picked up some ESR wheels this year. Fronts, 19x8.5 +30 Rears 19x9.5 +35 RF2 in Bronze. Tires are the stock Michelin Super Sports.
Mounted up my tires to my wheels from getyourwheels. TSW Neptunes in bronze. 18x8 +35 front with 245/45r18 and 18x9.5 +39 with 275/40r18 General GMax.
Slightly taller than stock tires. So far the ride quality is great and handling is way better than the stock a/s tires. Thinking about doing a slight drop later on. Also happy that TPMS self program on our cars.
Terrible Picture but got my Stance SF03s on today
Not a bad pic. Looking at these for my setup. What are the measurements on wheels and tires?
