Lord3Putt
So was it the +7psi of boost or the ethanol? Definitely not going to argue the fact that running the additional boost didn't accelerate the problem, but I doubt it was the only issue with the motor. Might've had something wrong with it from the factory that was going to happen eventually and this just sped it up.Nobody knows since there's no logs... but running a 7 psi with a guess on ethanol content Is a VERY likely culprit
Either way, I'm still, personally, going to run my E30 tune...even though the owner's manual tells me not to.
