Devin
1000 Posts Club!
Paging Dr. Gay....Right now, I’m deciding what exhaust system to get (I’m indecisive enough that I’ve just started a spreadsheet). I’ll get a Drgay and do some pulls with it to get a baseline.
my $.025The factory snorkel is the restriction there. It has a MUCH smaller intake hole and does two bends. Once you pressurize that box it is surprisingly efficient at moving air through it with a free flowing filter.
Water has no direction though - its not solid like debris so the grill adds little benefit (less than 2 ounces of water in a cylinder can hydrolock an engine). That said I was under the impression there were no turns in the snorkel leading me to making the statement. If there are similar bends then it may be okay, but again like anything there is an inherent risk.Big mouth snorkels have a bend in them too, honestly if any objects manage to squeeze past the grill, through the snorkel, go into the engine bay, penetrate the filter and damage your engine, you were already going to be F'd. And if you're getting enough water in there to hydrolock the engine you're probably nose-down in a lake.
Oddly enough my shopvac can pump water around quite a few bends. I believe that the surface area of the airbox is what prevents water from infiltrating. It has to contend with gravity and a huge (compared to the size of the inlet and outlet) area.Water has no direction though - its not solid like debris so the grill adds little benefit (less than 2 ounces of water in a cylinder can hydrolock an engine). That said I was under the impression there were no turns in the snorkel leading me to making the statement. If there are similar bends then it may be okay, but again like anything there is an inherent risk.
I only bring this up as my mechanic also builds race cars. When I asked him his opinion this was his response.
Acknowledging how this is probably not the most actionable comment, I do remember reading in another thread that the Velossa Tech (sp?) folks did a good bit of aggressive testing around the water question and couldn’t get more than a couple drops anywhere near the filter.
Save your money and get drop in panels from K&N or AEM while doing the snorkels. CAI are debated over and over and it comes down to looks and sound. Panels will run you $100 compared to $400 and 2 hours of your life to install. Panels take 5 minutes.Getting ready to do a bunch of upgrades at the end of the month, and after spending hours reading here, I can’t tell if intakes actually make any difference beyond improving the sound.
I am going to do scoops, exhaust, sway bars, brakes and a couple minor exterior items. I might do a piggyback tune. Likely, in fact.
I can’t find any evidence intakes change anything but the sound. In fact, there seems to be a consensus that aftermarket intakes reduce low-end grunt, which, living in a city, is where I have the most fun.
But maybe that equation changes if I do get the JB4? If I don’t do intakes, I will upgrade to AEM dry filters using the factory boxes.
Regardless, I’d rather put the $400 for intakes into better brakes or a higher quality exhaust if the only thing intakes change is to hear the blow off noises (which are very cool, don’t get me wrong).
Yeah I feel you but I just don't see how you even get two ounces of water into the engine bay under normal conditions, let alone past the filters and into the engine. These intakes aren't sucking puddles, they're mounted as high in the engine bay as you can get. I had an Altima with a CAI where that was a real concern, because the intake was sucking air from under the car instead of behind the radiator. Even then, I drove through pretty deep standing water (3-4") numerous times and never had a problem. Water just doesn't permeate through these cone filters that easily. If that was the case you'd have people hydrolocking at the car wash lolWater has no direction though - its not solid like debris so the grill adds little benefit (less than 2 ounces of water in a cylinder can hydrolock an engine). That said I was under the impression there were no turns in the snorkel leading me to making the statement. If there are similar bends then it may be okay, but again like anything there is an inherent risk.
My only performance mods at the moment are the Velossa Tech Snorkels and the AEM drop in panel filters with the JB4 on the default map 2.
wow, that answer enlightens me on your previous reply's.The factory boxes are a known restriction. With a turbo car you gain power by taking more air in and getting more air out. You can do it yourself with a 4 inch piece of pipe and a cone filter.
That's like driving around with no hood or front bumper!Lol I have intakes, snorkels and a vented hood. Drove fine in the rain and in cash washes. Just don’t try and drive though a lake.
I actually drove without a front bumper for a bit while it was getting painted. Just not in the rain.That's like driving around with no hood or front bumper!
