Daniel @ K8 Stinger Store
Authorized Vendor
- Oct 24, 2017
Is excited to present to the Stinger forums:
2.0T - K&N Typhoon Intake System
(BUY NOW)
Description:
Introducing the K&N Typhoon intake system for the all-new Kia Stinger 2.0T model. This intake replaces your Kia Stingers restrictive factory air filters & air intake housings. Designed to dramatically reduce intake restriction resulting in additional power & torque! Includes a Million Mile Limited Warranty and guaranteed to increase horsepower. This new K&N Intake system will make 5.4 HP and 11.3 ft.lbs TQ Gain (On the 2.0T engine). (Dyno Results HERE)
The K&N 69-5320TS air intake comes with dual black rubber topped K&N high-flow air filters and heat shields that install into the previous air box spaces. Air is directed through the intake tubes into the engine’s throttle bodies for a guaranteed power gain. The intake tube has an attractive silver powder-coated finish that's made to last and accommodate the factory mass air sensors and crankcase vent hose. The oversized cone shaped air filters can be used for up to 100,000 miles before servicing is needed depending on driving conditions.
Vehicle Applications:
2018-2021 Kia Stinger (2.0T Models)
2018-2021 Kia Stinger 3.3T: (FOUND HERE)
THANK YOU FOR LOOKING!
