If you want to do it yourself, it's pretty good - I did it on mine, and it turned out great.
In canada, I went with Carzillas Carpro CQuartz 30ml Kit with the Gliss topper - 2 coats ceramic and 1 topper.
That being said, I went fairly deep.
Thorough wash with Meguiars Gold Class, and I added a little degreaser/APC. 2 Bucket Method
Dry quickly.
Spray Iron Decontamination, wait, rinse.
Clay - used leftover soap as lubricant.
Dried, and left it overnight to fully dry everywhere just in case I missed a spot.
Single step correction with a DA polisher and Sonax Perfect Finish.
Wipe down with carpro eraser.
2 coats of Carpro Cquartz UK 3.0, waiting 12h between each
1 coat Gliss v2, 12 h after the second coat of ceramic.
Cure 48h, don't wash for the first week.
That took quite a bit of time, I was learning as I went. But it turned out pretty well, I have some old posts with pics.
But the prep is the most important part - the coating is very hard, and very thin, so it will highlight swirls, etc if they are there.
If you want to not worry about that, you can use a glaze, and that will have some filler properties, but it won't last nearly as long.
A similar package would have been about 900 I think. - I had the wheels done professionally though.
