CoconutRob
- Jul 9, 2017
Very nice, and 245 on front? No issues with 275?
Aren’t the rear 275/35s taller than the front 245/35s? The second number is a percentage, not absolute. To match the diameter of the fronts more they should be 275/30s.
245*.35=85.75mm
275*.30=82.5mm
275*.35=96.25mm
so the rear tires are 21mm taller than the front, since it’s 2x the sidewall height difference. 285/30 are an even better match but no way they’ll fit on those stock rear rims.
....but they do look gooooooood. I know what I’m buying after I shred my OE tires, thanks to you.
Better IMO - Slight increase to oversteer and I prefer it from stockHow do those drive compared to the skinnier stock Michelin’s? Looks much better, I’m definitely going to size up next time around. I got lucky and found someone local selling barely used stock Stinger tires for $500 (saved me about $600 over new).
No issuesVery nice, and 245 on front? No issues with 275?
Yes and that's not by accident. Also it's RWD so no big dealAren’t the rear 275/35s taller than the front 245/35s? The second number is a percentage, not absolute. To match the diameter of the fronts more they should be 275/30s.
245*.35=85.75mm
275*.30=82.5mm
275*.35=96.25mm
I've seen 285s on stock 8.5s but those guys are driving in straight lines. 285 could rip off the wheel if you're turning hard enough. be safeI still haven't had to buy new tires yet... But judging from those photos... 285/30's would look just fine!!
After seeing my to 265 on the rear I wondered about 275 but I would never try 285Better IMO - Slight increase to oversteer and I prefer it from stock
No issues
Thank you! Looks perfect
How hard are you gonna be turning? (Not trying to be an ass). I love how the 285's look.. I've had 265's on 7 inch rims running gymkhana never had problems...I've seen 285s on stock 8.5s but those guys are driving in straight lines. 285 could rip off the wheel if you're turning hard enough. be safe
No worries my dude. So in all of my research 275 is pushing the recommended limit of an 8.5” wheels. I don’t turn aggressively and originally planned to go 285 for my next set. Still might. I wanted to increase the width gradually to feel the differences it made. But I think i’ll only increase the aspect ratio now.How hard are you gonna be turning? (Not trying to be an ass). I love how the 285's look.. I've had 265's on 7 inch rims running gymkhana never had problems...
Would 275/40s fit? I just ordered 2 rear 275/40/19s Nitto 555RII.No worries my dude. So in all of my research 275 is pushing the recommended limit of an 8.5” wheels. I don’t turn aggressively and originally planned to go 285 for my next set. Still might. I wanted to increase the width gradually to feel the differences it made. But I think i’ll only increase the aspect ratio now.
I’m not turning very hard (most of the time), I have no issues with the 275 and yes 285s look amazing BUT I don’t want anyone reading through this thread and jumping to 285 then ripping their tire off on a hard turn without being aware that technically, 285s are well outside the threshold of a 8.5” inch wheel. It should be said that 285 will come with some bouncing at higher cruising speeds too
They ever get delivered? im curious. post some pictures.Will do! Fingers crossed until someone answers or they get delivered.
Yes they are at my local Tire Kingdom but I have scheduled an appointment yet.They ever get delivered? im curious. post some pictures.
Turning isn't going to rip them off of the wheel but they will most likely degrade at a faster rate due to the sidewalls being bulged outwards more than they were designed for which could result in a blow out, even going in a straight line.No worries my dude. So in all of my research 275 is pushing the recommended limit of an 8.5” wheels. I don’t turn aggressively and originally planned to go 285 for my next set. Still might. I wanted to increase the width gradually to feel the differences it made. But I think i’ll only increase the aspect ratio now.
Did you keep the stock profile of 40/35 or drop to 35/30? Time to replace my tires, just was wondering as I like your look.235 front 265 rear.
Whatever tire you choose, in the end, the rears must have the same tire diameter as stock, or your speedometer will be offDid you keep the stock profile of 40/35 or drop to 35/30? Time to replace my tires, just was wondering as I like your look.
It's not as sensitive as you may think. I have Tires that are 3/4" larger in diameter and my speedometer is only like a 1 mph off at highway speeds. Bigger issue is keeping the front and rear diameters close (within 3% is the general safe spot) if you have AWD to avoid damaging the center diff.Whatever tire you choose, in the end, the rears must have the same tire diameter as stock, or your speedometer will be off
