NSHFXstinger
- Nov 28, 2019
I have no idea. 72.4 lb is fedex`s number. But I do feel is light than stock.So it's heavy than the stock? What's the exact weight? Stock is 56.8lbs
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I just got mine in yesterday so i still had it in box. Weighed all the parts individually and it came out to 60.5 poundsSo it's heavy than the stock? What's the exact weight? Stock is 56.8lbs
it definitely doesn't weight more than the stock one... whoever did the install themselves cna tell you that the oem mufflers themselves are much heavier than the MBRPDarn if I would have known this I would have never bought MBRP. Cannot believe it weights more than stock. The whole point of buying was to reduce weight. Has no performance benefits and no weight loss benefit. Definitely going to do custom pipe in future. There isn't any!! Information on weight. Or exact gains.
you were able to hold both stock cans and the resonator pipes and stand on a scale? all at the same time? i'd love to see a photo of that for kicks. I can imagine one can over each shoulder and using the resonator pipe to keep the cans on you, but still...it'd be fun to watch.Installed pro series today on my '18 GT2. MBRP weight not including box or clamps was 59.7. Stock exhaust came out to 57.4 using my bathroom scale with me holding parts.
Install went OK but I'm pretty pissed for 1000 dollars they send clamps that cant seal and keep things from moving without having an impact. What clamps are people switching to that dont have access to a impact driver?
Sound is really good and drone not too bad with stock tips. Only issue is I need to figure out the clamping issue because it shifted slightly and rests on the stock tips on the passenger side.
Larger pipe normally weighs more last time I checked. Also a couple pound difference isn't going to change anything until your car is fully gutted and a full on race car.Darn if I would have known this I would have never bought MBRP. Cannot believe it weights more than stock. The whole point of buying was to reduce weight. Has no performance benefits and no weight loss benefit. Definitely going to do custom pipe in future. There isn't any!! Information on weight. Or exact gains.
Use a longer ratchet and hit it with your purse. you don't need an impact, I've installed lots of MBRP without an impact.Installed pro series today on my '18 GT2. MBRP weight not including box or clamps was 59.7. Stock exhaust came out to 57.4 using my bathroom scale with me holding parts.
It does make a difference when you are saving 10-20lbs. 60lbs ...I thought it would be at least 35-40lbsLarger pipe normally weighs more last time I checked. Also a couple pound difference isn't going to change anything until your car is fully gutted and a full on race car.
You think you're going to save half the weight on an exhaust?It does make a difference when you are saving 10-20lbs. 60lbs ...I thought it would be at least 35-40lbs
What's this imaginary exhaust made of??If I gotten the titanium valve control exhaust. That's possible. I haven't seen the weight details. But it's definitely lighter material.You think you're going to save half the weight on an exhaust?What's this imaginary exhaust made of??
At over 5 times the cost. I cant find any specs on diameter so you have to take that into account, TI is lighter but there will be more of it because its a larger pipe assuming same wall thickness. Which we come back to 30 lbs wont make a difference on any street car. Even at the strip 30lbs roughly equates to .03 seconds faster in the 1/4. Eat a couple salads and take aIf I gotten the titanium valve control exhaust. That's possible. I haven't seen the weight details. But it's definitely lighter material.
before your pass and save 3500$.you were able to hold both stock cans and the resonator pipes and stand on a scale? all at the same time? i'd love to see a photo of that for kicks. I can imagine one can over each shoulder and using the resonator pipe to keep the cans on you, but still...it'd be fun to watch.
Anyone who does exhaust mods for weight reduction or any serious power gains is going to be disappointed, on most cars. It's really a sound thing more than anything else.
I was using a 1/2" drive breaker bar. The problem is when using the breaker bar when you tighten it the pipe shifts and you have to move it again and realign. Even so the clamps look like they are completely bottomed out and the pipe is snug but still able to move a bit with some forceUse a longer ratchet and hit it with your purse. you don't need an impact, I've installed lots of MBRP without an impact.
Yes, leaks at the muffler clamps where the pipes turn upwards. The other clamps that are further forward have been fine for me.Couple questions as I've been contemplating the MBRP exhaust. First, do the the clams at the x-pipe also not get tight enough? Or is it only the ones near the mufflers? And second - do either of these seem like they'd be an improvement?
2.5" Stainless Steel V-band Assembly - Priced Each
Create a leak-proof connection for your custom exhaust project. Features locating ring for ease of alignment.www.ecstuning.com
