DeckardB26354
I'm pretty knowledgeable about cars but very new to the stinger. The car came with Kia OEM wheel locks (UM080-WPL01) for 18 inch wheels. The wheel locks installed are taper seat style. My 19" wheels are equipped with mag seat with washer style lug nuts. I pull wheel locks and reinstall lug nuts. I check the internet and OEM part #J5F44 AU000 shows to be correct for my car, they are taper seat as well. The wheels appear to be hub-centric. End up taking wheel locks back to Kia dealer to sort out. They basically offer to install OEM part #J5F44 AU000 for 19" inch wheels on my car. inform them they are the wrong style for my wheel set. Told "we can only install what Kia tells us to". Started talking safety and liability they quickly found the service manager. After a long discussion I think he understood you should not remove a mag seat lug nut and install a taper seat in its place. I had brought pictures to them to show them what I was working with. They made copies of the pics and told me they were starting an inquiry and I should have an answer in about a week. So happy with that. If need be I can sort out a wheel lock that will fit if Kia is unable to resolve. I am however worried that all over the internet it only shows taper seat wheel locks for the stingers 18" and 19" wheel sets when there are lug nuts installed on some wheel sets that are mag style and not compatiable.
So I say all that to ask this question. Is the Kia 19" wheel coming with either the taper lug nuts or the mag seat lugnuts? I looked all over the internet and could only find 19" wheels like mine that were set up for taper seat lug nuts. Is the AWD set up different from the RWD setup?
Factory lugnut and installed wheel lock. You can see the ring left on the wheel lock where it was contacting the edge of the bore. Wheels do not appear to have been damaged. All wheel locks were well below their torque value.
Wheel lugnut pocket.
Wheels appear to be hub centric.
Factory wheel set for reference.
