Climate control
squash
Does the stinger have a digital screen that shows what temp has been set in the car? Thanks.
Yes, but it’s only displayed in two situations. One, when you change a cc setting it will indicate it on the monitor. Two, you can select Climate to make the monitor show your climate settings.
An associated question -- is there an external temperature display?
In the instrument cluster. If you find a picture of that, you should see the outside temp displayed towards the left and on the bottom.
OK, good, thanks. Should have gone back and re-read the manual which I skimmed a week ago. Not many pictures in it, just drawings.
