NS_Stinger
2500 Posts Club!
- Jun 14, 2018
Those larger tips would look cool if it wasnt for the fact that you can see the crusty real tips so easily now haha
Not if the expansion ratio changes (i.e. higher than compression ratio). Atkinson and Miller cycle engines are able to achieve higher thermal efficiencies and overall efficiencies by raising the expansion ratio and leaving the compression ratio unchanged.While all of those things can make relative fuel economy better adding .2 liters of displacement ALWAYS decreases fuel economy if the compression ratio stays the same.
I won't disagree with anything that you said here, with the exception of the last paragraph. The increased expansion ratio converts more energy from heat to useful mechanical energy (work). From a calculation standpoint, this is precisely part of the definition of increased thermal efficiency. Making it about pumping losses or throttle bodies is less important because they represent a much smaller portion of the efficiency calculations.What you are describing reduces power. You would have to allow a greater volume of air in the Atkinson or Miller cycle to get the equivalent power. Thereby defeating the point of having a compression ratio that varies from the expansion ratio.
You could also decrease the throttle opening of the engine that had the same compression ratio as it’s expansion ratio. That would reduce power and use less fuel.
Atkinson and Miller cycle engines don’t actually provide fuel efficiency improvements because of the difference in compression ratio vs. expansion ratio. That is a common misconception. They actually provide benefits from eliminating the throttle body and that benefit is limited.
Looks silly with the large fake tips and small actual exhaust pipe.
Here’s the tiny exhaust lol
View attachment 48845 Here is the latest 2021 rear tail lights undisguised picture could find.online...
Well those interior shots look really good but man the rear change just doesn't do it for me. Especially the large fake tips when you can clearly see the real exit being so much smaller
Is that blue supposed to be the Indigo?
more info. I like my 2020 style vs this new one.
