Since I'm a rabble-rouser....
@Mike_TX - Not counting the tank it came with, I'm on my second tank of gas on my new base GT. The first time I filled it up with 93 (AKI not RON); this last time I filled it up with 87. What will I do on my third tank? Probably 87 again.
YouTuber EatSleepDrive did an interesting video using his Fiesta ST. He filled it with 87 and ran it on the dyno. He then drained the tank, filled it with 93, and ran it on the dyno again. There was, not surprisingly, a power difference; 93 gave higher numbers than 87 did (181 hp max vs 171.4 hp max, ~5% difference). What was more interesting, though perhaps also not surprising, was that over the course of several pulls, there was a much bigger drop-off in power using 87 than there was using 93. The delta between the highest and lowest hp numbers on 93 was around 5 hp; the delta for 87 was around 10 hp.
With this in mind, I'm not a red light racer. My heaviest use of the accelerator pedal comes when I'm merging onto the freeway or passing someone on the freeway. So the performance drop-off over several back-to-back-to-back pulls is pretty irrelevant to me. So too is the ~5% difference in max hp. Max hp is reached at around 6000 RPM for the V6, and I'm rarely if ever spinning the engine that quickly.
If I were taking the car to the drag strip or the track regularly, it would be a different story. But for my needs, I doubt I'll miss the small drop in performance.
Here's the video:
