Window rattle
GeoUTA
Just wondering if anyone else has experienced a window rattle (driver door for me). While it may be occurring at high speeds you really can't hear it but at <40 mph it is persistent and obvious. If the window is down, no rattle. If the window is essentially closed but cracked so slight that you can't even tell, no rattle. Only when the window is fully shut and sealed does it start rattling around. Anyone have any experience like this or any ideas what might be happening?
Thank you all! :)
Is there an easy fix where the sun roof seems to lowkey "squeek" when closed? Sounds little like 2 plsatic/rubber parts rubbing against each others in my car.
Wedge something between the front seal and the frame. I use a folded over felt coaster. Totally silent.
